  • MTN Ghana SAYS MY PHANTOM 6 PLUS ISN'T 4G SUPPORTED. Ghana
    I dial the short code *585# and selected option 2 to test the compatibility of the phone on their so called 4G network, but feedback given was negative. Who is lying, TECNO or MTN Ghana?
    screenshot the message u got
    Earnest, Nigeria.
    Manager GMC XCLUSSIVE
    Quality Service is our goal
    Greetings from Tecno team
      screenshot the message u got and post it here
      Earnest, Nigeria.
        That's what MTN Ghana says I have changed Sim to the so-called 4G.
          It's true, they are telling me the same thing
            its a lie...i got the same message....bt i went there and they were saying same but when they did it...it worked<br />
            go to the nearest service centre and get it done<br />
            am really enjoying mine
              Take your phone to their centres.
                Kindly send back you're sim card to MTN center for a better service on your phone, but please tell them to select the AUTO option.
                Thanks.
                  MTN tells me the same thing that my handset does not support 4G but I am experiencing 4G with my mtn SIM card.
                    Please my phantom 6 plus camera is not clear at all as compare to my C9 camera. Meanwhile the phantom 6plus pixel is higher than that of the C9. Any help?
