  • charging port replacement Others
    Hi all,
    I have a problem with my phantom 6 plus charging port and i have to replace it.
    In my county there are no "distribitor" of tecno...
    Could you help me to find the reference of this port (USB 2.0 type 3) or which brand use the same port.
    thank you
    Your country?
      What the name of ur country?
        Dunno if there is a Carl care centre in your country. Look up the Carlcare app on your phone for more info
