  • phantom 6plus can VR box work with the phantom 6plus Nigeria
    hello phantom 6 plus users, I just want to know if VR( virtual reality ) box can work with phantom 6 plus. because I want to buy a VR for my phantom 6 plus
    Yes it should work but it have limited access to some features because phantom 6+ doesn't have all the required sensors.
      Yes! Without a gyroscope and magnetometer sensor which the phantom 6 lacks, you can still watch side-by-side 3D movies and videos, but most VR apps won’t work.<br />
      Most VR apps use a phone’s gyroscope sensor, which affords users a 360-degree spherical view of their virtual world.There are some apps that'll work even if your phone doesn't has a gyroscope like "Space VR demo for Cardboard" is suitable for devices with no gyroscope.
        thank you for the informationsss
