  • Phantom 6 plus boot loop Ghana
    I had this boot loop problem fixed by calcare 3 weeks ago, lost all media files.. and now its back.. is there no work around to do hard reset (gonna loose files anyway) myself than sending it to calcare everytime to get it flashed ? Phantom stress!!
    What exactly caused the Bootloop ?? You tried to root it or ??
      No not rooted.. saw some message dont remember exactly (some temperature thing) while making a call and the phone turned off. I never get pass the tecno logo anytime i try to boot
        Sorry to hear this ... Okay ,, Do you have a pc ?? Do you know how to use Sp flashtools ?? If yes ,, then download the Rom and flash it with sp flashtools ,, i can give you link to the Rom files ,, But if You dont have a pc or dont know how to Use sp flash tools ,, Am afraid You have to take it to carlcare
