  • PHANTOM 8'S EYE CARE FEATURE WILL HELP YOU SLEEP BETTER All
    Your mobile device’s display emits a mixture of red, green and blue light. Varying the intensities of each color of light allows for the display to produce different colors as needed to display your images and text
    Displays in general, tend to produce a relatively large amount of blue light which is fine for daytime use but research has indicated that exposure to blue light at night can affect a person’s sleep cycle due to the suppression of the production of melatonin, which is a hormone that makes us sleepy at night.
    The research indicates that exposure to their blue light at night prevents us from falling asleep as quickly as we should, subsequently reduces morning alertness.
    Eye care is Tecno's solution to counteract this issue. Eye care reduces the amount of blue light emitted by the device’s display and increases the amount of red light, resulting in a warmer colors being displayed with the aim of facilitating better sleep at night.
    HOW TO USE EYE CARE
    • Eye care can be activated from the quick toggles on notification tray
    • It can also be turned on and further personalized the intensity from display setting found in the setting app.
    It is most recommended this feature is turned on at night. I hope you enjoy using this feature and enjoy you Phantom more.
    Peace!
    Creamtech.com.ng
    IG/TW @dc7official
    gud day does phantom 6+ have this features of EYECARE?
      no it doesn't
      Creamtech.com.ng
      IG/TW @dc7official
        Wow! An eye care feature? This Tecno Phantom 8 is a must buy.
        • Onoja commented
          For real
        Cool feature.
          This is actually useful. Aids the eyes.
          • Onoja commented
            Really useful and helpful
          This phantom 8 is the total package of everthing nice amd in between
            I wish my phantom 6 have this feature
              sure it helps at night time
                These are part of thw things that will make you want to consider buying Phantom 8 o
                  useful feature indeed
                    This phone is crazy.... Am so loving it.
                      Pls kindly assist as the 3 lower button on my phantom doesn't illuminate at night. That is the home key, the middle key n the back key.... Any settings?
                        what kind of Tband is compatible with phantom 8
                          Why not the Tecno team update P6 to use this feature?
