  • dimmer problem Egypt
    when I reduce the dimmer manually or when it decreased automatically after a period of non use. the back light flickered. it is annoying matter, can anybody help
    please Try to remove memory card and try make factory resetting your device and if problem doesn't solved please visit the closest carlcare center to you sir
      do you have any reasons for that,please don't paste a fixed reply for all problems
        if you want know the reason of phone problem you can visit Carlcare branch and check your device ....
