  • Help Techno Phantom 6 Plus Hanging Problem Others
    I have problem with my phone. It will hang when I will close the phone book and then it is in the clock still it will hang and after that I press power button for shut down option then it is okay. Please solve hang problem. I bought this from Saudia Arabia.
    @tashbigold<br />
    Sorry about that, please what OS version is the phone running? 6.0 or 7.1?
      I have the same Problem.<br />
      It is running Android OS 6.0. <br />
      Originally posted by lummyfinest
      @tashbigold<br /><br />
        Originally posted by Naipuli
        I have the same Problem.<br /><br />
        It is running Android OS 6.0. <br /><br />
        @tashbigold<br /><br /><br />
        same problem
          Please search for the latest update version release For Phantom6Plus, you can also follow this official guide for assistance<br />
          http://bbs.tecno-mobile.com/forum/ph...k-included-now
            I assure you that by restoring factory settings your phone will fine.
            I have the same Problem.<br /><br /><br />
            It is running Android OS 6.0. <br /><br /><br />
            @tashbigold<br /><br /><br /><br />
            <br /><br /><br />
            same problem
