  • Help needed urgently All
    I did a system update on my phantom 6plus and since my finger print stopped functioning. The new update came with an upgrade on the eye print to face ID upgrade.
    Maybe you should do a device backup and wipe the phone for better functionality. If the problem permits, visit Carl Care nearest to you
      [QUOTE=mprinceotu;285272]Maybe you should do a device backup and wipe the phone for better functionality. If the problem permits, visit Carl Care nearest to you <br />
      I did a factory reset but nothing changed.
        Visit Carl Care nearest to you [QUOTE=979685185;285306]
        Originally posted by mprinceotu
        Maybe you should do a device backup and wipe the phone for better functionality. If the problem permits, visit Carl Care nearest to you <br /><br />
          Take the phone to Carlcare and complain. They will help you find a solution
