  • Phantom 8 speaker volume low Kenya
    My Phantom 8 speaker suddenly went low on volume I can barely hear when I'm called. What could be the problem? And how do I fix this
    Tecno AX8
      You may have installed a third party app that can control the volume of your device. If you did, check the settings of the app and adjust the volume. If you didn't, you'd have to visit the Carlcare Center nearest to you for solution.<br />
      Good luck.
