  • problem with intelligent cover All
    After opening myTecno intelligent cover, my phone remains blocked on the clock screen and change all my background picture when I restart the phone Please How can I fix it ? I have the 7.1.1 android version on my phantom6+ thx for your support
    did you update boomplay? if so, try removing the update.
      @nabish<br />
      I already experienced the same thing despite the fact mine is still running 6.0 OS but i fixed it, try to restart your phone and set your HiOS launcher to default mode.<br />
      Also avoid updating the HiOS launcher or stop any 3rd party launcher. Visit Carlcare service if nothing works.
        Originally posted by lummyfinest View Post
        @nabish<br />
        Thanks for this info
          Follow the advice of lummyfinest
            Thanks everyone for your feedbacks. <br />
            I will let you know the results
              Hi everyone,<br />
              As promised I come back to you to share results about my troubleshooting.<br />
              After several tries and monitoring, I can confirm you that the root cause of my problem was the update of Boomplay as mentioned by gachokaeric819. Special thanks to him. <br />
              Thanks also to all of you for your attention to my post and for your replies. <br />
              Be blessed and have a good day.
