  • Tecno Phantom 9 Specifications And Unboxing Nigeria
    Hello Tfans
    The Phantom 9 was launched on the 4th July, 2019 at Eko Hotel and Suites Victoria Island in Lagos. The device is the latest in the Phantom line, it is fully crafted in lapland Aurora crystal clear design body featuring an on screen fingerprint scanner, a massive 6.4 full HD Amoled display and a Triple AI back camera.
    KEY SPECIFICATIONS
    • Display: 6.4 Full HD Amoled
    • Resolution: 2340*1080
    • Dimension: 158.46*75.3*7.85mm
    • Camera: 32MP Front Camera with Dual Flash , 16MP+2MP+8MP Triple Rear Camera with Quad Flash
    • Memory: 128GB ROM + 6GB RAM (Can be expanded with SD card).
    • Processor: 2.35 Ghz Octa-core
    • Battery : 3500mah
    • OS: HIOS 5.0 based Android Pie 9
    • Color: Lapland Aurora
    • Sensor: G-Sensor , Ambient Light Sensor, Proximity Sensor , Fingerprint Sensor , Electronic compass
    • Network and Connectivity: 4G , Wifi , Bluetooth, 3G and 2G
    • SIM: Dual sim( Nano)
    The Phantom 9 box is protected with nylon to prevent from dust and moisture which I removed before the start of this unboxing since we all eager to see it
    The device comes in a shining rectangular shaped grey box. The box is engraved with Phantom 9 inscription on both sides and the top. With a larger picture of the smartphone which beautifies the front cover of the box showing it water drop notch.
    Upon opening the device you find the Phantom 9 device, a case , warranty card , the user manual , sim injector pin, charging adapter , USB cable and earphone.
    The device looks sleek and beautiful with it Lapland Aurora design. The design was spot on
    The back of the device only houses the triple AI camera and the Quad flash. (The fingerprint is on the screen display).
    The body of the device is simple and isn't complex with the USB port , earphone jack , microphone and speaker grill all at the bottom.
    The volume rocker is at the right side of the device while the hybrid Sim slots (Two Nano sim and a single SD card) is at the left.
    At the top of the screen is the 32 MP Selfie camera, speaker for calls, dual flash lights for night selfie and video calls.
    Settings up of the Phantom 9 was swift and easy. The device runs on Androidâ„¢ 9.0 Pie and HIOS 5.0.
    Overall the Phantom 9 is a remarkable device, based on a first impression. The recommended retail price is 77,000.
    What do you think of the Phantom 9?
    No two ways about it, the device is innovating, superb and affordable. I can't wait to have it this month with the exchange for my Camon X
      how do u exchange normaly do d exchange
        we need this font issue to solve once and for all, stop lunching phones that are not necessary
          Is it possible to swap with phantom 8 which is relatively more expensive. What are the conditions if possible.
            This device is nice
              Carlcare will be in a better position to answer that
              Originally posted by Ardotman
              Stupid phone without font.I Know DAT you guys As Started Giving Us A Dirty Lie's Again.What's The Essence Of You Buying Phone Without Font.Pple Are Complaining about the Font issue u are busy unveil 1kind Stupid phone without font You Know That You Can't Compete With HUAWEI & Samsung
              There is font on the Phantom 9
                Carlcare does the exchange
                  I just realized the Phantom 9 is out. How I didn't know of the launch earlier, I don't understand. Maybe a lack of proper publicity for this phone.<br />
                  The Phantom 9 has awesome specs but I'm still disappointed.<br />
                  The "Phantom" is supposed to be the best smartphone TECNO can come up with. Why the h2ll won't they keep it that way?!<br />
                  The Phantom 8 didn't sell as much because it was only just a slight bump in specs from the Phantom 6 Plus ... people didn't see the need to upgrade.<br />
                  Now, the Phantom 9 is more like a downgrade ... without fast charging, Type-C gone, smaller battery .... Geez.<br />
                  TECNO have had almost 2 years of technological advancements to make the Phantom 9 significantly better than the 8 and 6 Plus ... but No, still just a slight bump.<br />
                  TECNO should have kept the Phantom as a premium line .... not everyone looks to budget smartphones.<br />
                  I'm heartbroken!
                    how much of tecno phantom 9
                      Originally posted by YungProf
                      I just realized the Phantom 9 is out. How I didn't know of the launch earlier, I don't understand. Maybe a lack of proper publicity for this phone.<br /><br />
                      The Phantom 9 has awesome specs but I'm still disappointed.<br /><br />
                      The "Phantom" is supposed to be the best smartphone TECNO can come up with. Why the h2ll won't they keep it that way?!<br /><br />
                      The Phantom 8 didn't sell as much because it was only just a slight bump in specs from the Phantom 6 Plus ... people didn't see the need to upgrade.<br /><br />
                      Now, the Phantom 9 is more like a downgrade ... without fast charging, Type-C gone, smaller battery .... Geez.<br /><br />
                      TECNO have had almost 2 years of technological advancements to make the Phantom 9 significantly better than the 8 and 6 Plus ... but No, still just a slight bump.<br /><br />
                      TECNO should have kept the Phantom as a premium line .... not everyone looks to budget smartphones.<br /><br />
                      I'm heartbroken!
                      Not just you man. My heart is literally shedding tears. <br />
                      Would it have killed them to use a Type-C charger?
                        hello!! how can i get the phantom 9 in Cameroon. and howmuch?
                          is like every carlcare for tecno and itel can do the exchange? your assistance is much appreciated.
                            Do you have the device to know if there is font or not? <br />
