  • HOW TO SET UP PHANTOM 9 IN SCREEN FINGERPRINT SENSOR Nigeria
    The TECNO Phantom 9 is the latest addition to the line of the Phantom series and one of the interesting features of the device is the in screen fingerprint scanner, which is embedded into the phone’s display.
    This makes it more convenient to unlock your phone compared to previous back cover fingerprints sensor.
    The reader, which is designed toward the bottom of your device screen, record your fingerprints information for enhanced and improved security.
    The In-Fingerprint scanner can also be used to unlock and access applications.
    Here's how to set up your Phantom 9 inscreen fingerprints
    Open the settings app on your Phantom 9 scroll down and select "Security & Location".
    Select "Fingerprint" to add fingerprints
    Set up your additional security option and proceed.
    Tap on Add fingerprint
    Read instructions on the screen and tap on START
    Follow the prompt and begin scanning your finger by placing it on the scanner. Lift your finger off the screen and place it back until you get a fuller scan.
    Reposition your finger to capture the edge of the edges of your fingerprints.
    When your scan is completed, tap on FINISH
    You've successfully registered your fingerprint.
    Place your finger on the scan area to unlock your device.
    NB. You can add up to five fingers at a time.
    Questions are welcome.
    nicr
      Originally posted by sssssu
      nicr
      GHG
        nicr
        GHG
          nicr
          GHG
            nicr
            GHG
              Hank
                how much is phantom 9?
                  nicr
                  Habsburg
                    Originally posted by sssssu;3328hhh50
                    nicr
                    GHG
                    • 0777961023 commented
                      How will you add up to five finger print
                    night ft I've
                    GHG
                      Hotspot Shield Crack– is very powerful and capable VPN (virtual private network) software. It is easy to use and User-friendly Software.
                        It goes for N77,000
                          Nice and easy steps
                            is it on phantom 9 phone alone
