  • My Phantom 8 problem Nigeria
    Hi, I discovered today that my new Techno phantom 8 can't accommodate 2 SIM cards and an SD card at the same time. It's either you use two but not the 3 together. Why is it so? or I'm I not doing it correctly. There's no inbuilt manual in it too. I would really appreciate if you respond urgently. Thanks.
    That's the way it is.
      The phantom 8 comes with a hybrid sim slot, thereby allowing you o use two Sims at the same time or a sim and an sdcard.
        That is the way the phone is. You are not doing anything wrong.
          i think its pretty normal, nothing is wrong with it
              Okay. Thanks.
