  • restarting Kenya
    My android restarts itself once or twice a day. Any help?
    That's a problem, did you notice when it started, was it after downloading a particular app?<br />
    You might need to update your device to a recent security patch if you have already done that, then you will have to do a factory reset after backing up your device to get rid of the problem causing the restarting.
