  • My tecno phantom 9 is faulty Nigeria
    My new phantom 9 is having multiple issues and i just bought it a week ago its freezing whenever am typing the screen went blank for few seconds the speak stopped working till i restarted the phone am not enjoying my phone at all
    factory reset if the issues persist then take it to Carl care for a fix
      I factory reset it already but still persist and i dont know where carl care is
        Open your Carlcare app and locate the Carlcare center nearest to you.
          Alright i have done that
            Then go to the Carlcare and have it checked out, I hope the device is updated and the screen protector is the correct one for the device
              calcare will solve it
                I took it there already and its been more than a week now and they haven't found any solution to it till now just kept saying not available yet
