  • Tecno Phantom 9 Kenya
    Hello, I just bought phantom 9 3days a go but its unfortunate that it can't detect my SD card 64gb which I have been using in Camon 11pro. What is the problem?
    What is the error message? What do you mean by detect?<br />
    Please explain
      Originally posted by tolugaruba
      What is the error message? What do you mean by detect?<br /><br />
      Please explain
      Detect meaning the phone doesn't seem to find that SD card has been mounted
      • tolugaruba commented
        Then the card might be faulty, or need to take the device and card to the nearest Carlcare for assistance.<br />
        Since it was functional in the camon 11 , maybe he needs to format as portable with the camon 11 first before he inserts it in the phantom 9, that already has enough rom.
      Pls how much did u buy your own?
      • Ennyholar commented
        The recommended price is 77,000
      the SD card might be faulty why not use the one that came with the phone
        Tecno doesn't release phones with SD cards now a days
          Please use a PC to format the SD card. If it can't be detected on PC then it's fake.
