  • Phantom 6 Plus Unboxing and Quick Review Nigeria
    The Phantom 6 and 6 Plus was unveiled last Sunday at the Burj Khalifa Tower
    in Dubai. Much have been said about both devices and we have seen the Beauty
    in the Beast of
    these devices...
    Today i personally will take you through the unboxing of the BEAST
    THE PHANTOM 6 PLUS
    HOLD ON......THE SPECS
    Name Phantom 6 Plus
    Model A9
    OS Android 6.0 with HIOS
    Processor 2.0 Ghz Deca-core
    Band GSM:850/900/1800/1900
    WCDMA: 900/1200
    LTE: Band 3/4/7/20
    Design 160.35*83.46*7.7mm
    Display 6.0'' FHD LTPS Touchscreen
    Resolution 1920*1080
    Camera 21MP AF Back Camera with Dual Flash and 8MP Front Camera
    Memory 64GB ROM + 4GB RAM
    Connectivity GPS ,WIFI,BT ,USB, OTG
    Sensor G- sensor, Ambient Light Sensor , Proximity Sensor
    Battery Capacity 4050mAh
    USB Type - C Light Speed Charge
    THE PACKAGING
    THE Phantom 6 Plus back in a black beautiful box with 6 in gold on it.
    Inside the box there is two compartment boxes..
    The first box with GIFT written on it contain a Cover,Tempered Glass, Earphone , Sim Injector
    and a C type USB cable.
    The second box contain the 4GB RAM and 64GB ROM Beast carefully arranged..
    OPENING THE SIDE ON THE BOX YOU SEE THE SPECIAL WARANT CARD , PALMCHAT CARD
    AND THE MANUAL.
    UNDER IT IS TWO CHARGER ADAPTERS (A DOUBLE PIN AND A THREE PIN) AND THE USB C-TYPE
    NEATLY ARRANGED....TECNO GAT MY LOVE WITH THIS ONE.
    THE DEVICE IS BEAUTIFULLY CRAFTED WITH FULL METAL BODY
    THE DEVICE IS SLIM 7.7MM SLEEKY BODY I WONDER HOW TECNO FIT A 4050MAH BATTERY INTO THIS BODY..
    WITH THE VOLUME ROCKER AND THE POWER BUTTON BY THE SIDE.
    THE DEVICE IS POWERED WITH SONY 21MP MEGA PIXEL BACK CAMERA AND 8 MP FRONT CAMERA
    WITH AN 80MP SUPER PIXEL FUSION IMAGING.
    THE CAMERA IS POSITION IN THE CENTER BACK OF THE DEVICE
    UNDER IT IS THE FLASH AND THE FINGER PRINT SENSOR
    THE SIM CARD SLOT IS AT THE SIDE
    THE EARPHONE IS AT THE TOP OF THE DEVICE
    AT THE BOTTOM IS THE USB TYPE C CHARGING PORT AND THE SPEAKERS.
    HERE IS THE VIEW OF THE DEVICE WHEN POWERED
    THE END THANK YOU..............MORE TO COME ON PHANTOM 6 PLUS
    nice review
      I see it like the front camera is not centred as in c9, or maybe it's the problem of my eyes.
        You tried. You should have done a video intead though.
          I really envy users of this beast o
            Take me through the beast by giving me your own oga!
