  • UNBOXING THE PHANTOM 6 PLUS AND FIRST IMPRESSIONS Kenya
    UNLEASH THE PHANTOM
    The phantom 6 plus is a bigger version of the phantom 6, it comes with two colors star grey and champagne Gold , being a plus it comes with outstanding specs which include a 64 GB internal Memory, 4 GB RAM and a Mediatek Helia Deca core processor. The device I am unboxing comes in champagne gold color.
    The phantom 6 plus is packaged in a black box which is very simple with just phantom 6 plus inscribed in it in a rose gold color, I’m saying it’s simple since the packaging doesn’t contain 'shouting' images such as the one on the Camon C8 As you all know, Simplicity is the ultimate sophistication.
    I will have to admit the packaging feels really expensive There are 2 boxes inside one is branded ‘GIFTS BOX’ reason? This particular box has:
    1. Earphones, not just your ordinary earphones but the BOOM NB1 which deliver great bass and clarity plus they are metallic.
    2. You also get a tempered glass (screen guard) it is advisable to remove the protective paper on the device before installing the tempered glass.
    3. There is also a usb type c adapter, this is important for connecting the phantom to conventional Micro usb cables
    4. You also get a smart flip cover just like the one on the camon C9 which can support your device Learn more here
    5. There is also a sim ejector tool, the phantom 6 plus has a non-detachable battery and considering its sleek and slim design the only part that opens is the sim tray: here you can insert two simcards , a Micro and a Nano one you can also insert your memory card (which you may not need,the phone has 64GB internal Rom )
    On to the next box where the phantom 6 plus is housed you will find the phantom 6 plus on further opening you will find the usb type c cable, a charger and two socket extensions You connect Depending on your power outlet.
    The phantom 6 plus is full metallic and its very slim measuring just 7.7 mm considering it has a huge 4050 mAh battery under its hood. The speaker is at the bottom, just like on the Tecno boom J8.
Name:	3 spreakers.PNG
    The 21MP SonyTM back camera is a bit protruding, a protruding camera is not that good since it may be the first to feel the impact in case the phone drops and this may break the lens , but Tecno thought about this too and to make sure this doesn’t happen they used a durable 9H sapphire glass and embedded it into a two layer aluminium structure to offer seamless protection for the lens resolving any concerns you might have ,simply launch the camera and start imaging creation where you like.
    On the front, there is the ambient sensor an 8 MP front camera and soft flash the name phantom is engraved at the bottom bezel since the phone comes with soft on screen navigation keys.
    Here are all the things you'll find in the box in one picture
    Conclusion
    The phantom 6 plus is a very beautiful crafted device as well as very powerful , considering its sleekness and slim design I was surprised to see that Tecno didn’t sacrifice the battery, and also the 3.5 MM audio jack is still intact , it comes handy at times, If you have ever dropped your phone only for the wired earphones to save it you will understand.
    oh one more last thing have a look at the warranty card:
    The guarantee that Tecno gives you
    At least I can guarantee you it doesn't blow up
    the warranty is pretty cool. with the 3 months insurance, my carelessness is covered
    • Tania Delhunco commented
      smh for u
    • peter Boom commented
      haha there is a free tempered glass for people like you
    • nelsonajah commented
      am a construction worker, and we deal on hard surfaces. u kw what i mean @ peter
    i can see gifts crested on the pack. whats that for pls?
    • jerrywatago commented
      is the type c usb, tampered glass and the earpiece that is in it.
      thats good packaging o..was thinking xtras.
      I need this Phantom 6, sponsor ajitokeze
        hahaha have you considered advertisising kidneys
      Wow. This is nice. The last line got me laughing. Tecno phones don't heat sef.
        its well designed to avoid heating.
      Hop Mach is il ; phantom 6 plus ?
        the best price i have seen so far is 30K
      How much is il ?
        which of the phantom device?
      Cool
        Even looks better than the phantom 6...nice
          The USB TYPE C charger is an incredible Advancement!! Fast charging on the Go!!!
            plus faster data transfer
          • Smartnigerian commented
            And they said Tecno isnt the best, i laff in Isheri
          I know but this Spec. is just too much.. i feel like 4GB RAM!!! Wow.. I was amazed, don't expect this from Tecno!! Good Job
            expect the unexpected maybe phantom 7 will be waterproof
            would be nice..but that wont happen anytime soon
          The Accessories are Beauitful, Really!!! I'm loving that earphone. i'm sure it'll sound better than other previous headphones
          A great device in 128,000 ways.
          Everything you expect from a flagship. Tecno s officially a premium smartphone maker.
          took delivery of my Phantom 6+ on Thursday and am so loving it... was wondering though... How do I screenshot on the Phantom 6+?
            pull down the notification drawer and you will see the screenshot button just below the mobile data switcher
            I thought der was another way?
            slide down three fingers
